Go Back   SEMB Muscle Car Club > Tech Section > Mopar - Muscle Car Development > Mopar Other
Old 07-10-2006, 10:52 PM
Remy-Z Remy-Z is offline
Diplomat Electrical
:smt017 ...I have been chasing this damn thing down for about a month now! I have a problem where the wire that connects between the alternator and the battery grounds out...disconnect the wire at the battery, jump car, it runs fine...but kills the battery. While car is running, touch wire, and you could probably weld with that spark. The wiring in the charging system is fine, I've gone over it about half a million a!'! times now, all for nothing. Here's the readings, with battery at an even 12V:
Grn wire at alt to ground: 2.7V
Blu wire at alt to ground: 2.7V
(@ Voltage Regulator) Blue wire-nothing
Grn wire- 6.2V
It's the right alternator, and there is no visible grounds...?
Mechanical work and swearing go hand-in-hand.
2001 Buick Regal GS JA Edition, 3.8 s/c
1987 Dodge Diplomat 360/4-spd
Old 08-16-2006, 09:09 PM
The_Dakota_Kid's Avatar
The_Dakota_Kid The_Dakota_Kid is offline
http://www.moparts.com/Tech/Archive/elec/21.html
This will help 1st you need to figure out whats bad, 99% of the time its a bulk head connector, the main charging wire from the alt runs through a bulk head and the gage in the dash before it goes to the battery.
Web Advertising - Advertising - Advertising - Online Advertising - Online Advertising test
