No, I knew a little of it, like the bench bleeding. That's why I was asking. I've done a million things, but never replaced a MC so I wanted to make sure to do it right.
I'm going to flush the entire system, so any air that gets in there will be cleared out anyway. I'm just worried about it getting into the ABS pump. I heard if it does, it takes a special tool to bleed that or whatever needs to be done to remove the air from the pump. I guess if I don't start the pump I'll be okay, right?
As for the hose, I was talking about the hose that comes out of the side of the reservoir. Should I clamp that one off? What does it lead to exactly and how can I get the old fluid out of there?
I know I should pick up the manual, but no one carries the one that covers my car. Only found the old school RWD LeSabres (wouldn't mind one of those!!!).
EDIT: Where can I find the order to bleed each brake at?
