Old 05-06-2006, 10:47 PM
kvanmaanen's Avatar
kvanmaanen kvanmaanen is offline
Polyurethane Vs. Rubber Bushings?
My 68 Camaro need's new bushings and I have been researching and am gettting mixed opinions. Rubber deteriorate and poly squeek. any suggestions?
'68 Camaro with a Gen III 6.0 Liter LQ9 w/ 4L60-E.
Old 05-07-2006, 12:31 AM
put grease on the polys to eliminate squeeks, :smt023
Old 05-07-2006, 01:55 AM
aye poly all the way, they are way more durable and a little tighter, you will like them, as long as you lube them up real good!
Old 06-11-2006, 07:25 PM
greasemonkey greasemonkey is offline
Send a message via AIM to greasemonkey
I've had good results with polygraphite being durable and not squeaking. not sure who else makes polygraphite, I've always gone through P-S-T.
and yes, for any kind of performance the rubber sucks and it does deteriorate pretty quickly as they don't hold up to heat, oil and high pressure very well.
Old 06-12-2006, 08:28 PM
turbo nasty turbo nasty is offline
Got polys on my upper and lower control arms on my 87 and aslo in the rear lowers and no squeaks.
What a difference in the handling ...BIG difference over rubber.
I vote POLY
87 Grand National- Hopped up
86 GN- hopped up
05' HDs w/EFI bikes are massaged a lil bit
Dyna Wide Glide- Glacier White Pearl
Softail Duece- Sunglo Blue & Chopper Blue
Old 06-13-2006, 08:04 AM
Joe Joe is offline
Send a message via AIM to Joe Send a message via Yahoo to Joe
poly is better for the stiffer ride, etc.
Rubber bushings will generally last you many years without problems :smt025
Joe
1967 Chevy Stepside - current restoration project
1967 Camaro RS/SS L78 Coupe
Michigan Classics
Online Advertising - Free Advertising - Online Advertising - Advertising - Free Advertising test
