Old 03-07-2006, 04:11 PM
83-z 83-z is offline
Send a message via AIM to 83-z
rough idle....shit
i just put new heads and an intake on my 305 4bbl. it has more power it seems like but it isnt running verry good.it hesitates to turn over some times....turn key off and then try again and it works?¿ im confussed... :smt090
Old 03-08-2006, 12:47 AM
illegal84regal illegal84regal is offline
Send a message via AIM to illegal84regal
im probably gonna sound stupid but did you make sure everything was adjusted in the heads?...also maybe a retime...
Chris Sneesby
1988 Mustang LX Notch 5.0: BBK shortys, flowmaster x-pipe/american thunder exhaust, 3.55's
1984 Regal---350SBC, TH350, Edlebrock cam/intake/lifters, Holley 650 carb, 3" side exit exhaust, shift kit, autometer tach, subframe connectors,weight reduction,relocated battery etc etc
Old 03-08-2006, 12:57 AM
Default Default is offline
It could also be something fuel related. Such as your fuel pump might be going out.
1993 Purple Pearl Metallic Camaro Z28 A4
13.49 @ 101.80 -N/A
12.83 @ 111.85 -100 shot
Mac midlength headers, 3 inch high flow cat, 3 inch cutout, Magnaflow muffler, mail order tune, and 100 shot
Old 03-08-2006, 01:33 AM
^ thanks i knew i was forgeting something....
is it a carbed motor...was there anything wrong before the heads?
if its the carb...clean it up a little bit..check the fuel filter and the fuel pump...
Chris Sneesby
Old 03-08-2006, 08:07 AM
vacum leak maybe
Old 03-08-2006, 09:58 AM
may have to adjust your carb to compensate for the new intake.
Old 03-08-2006, 06:24 PM
thx guys.. i should have put this but i forgot, the heads and intake are stock replacement rebuilt with 0 miles..... im sure i have a vacuum leak and im going to try that. also the fuel pump is new so i hope thats not it. ill keep u posted. thx
Old 03-09-2006, 11:43 PM
if you put a new intake on it id adjust the idle speed up, when i put my holley on it was idleing rough and i hook my tach back up and i was doin bout 400-450 rpms, i set it around 700rpm idle and 1400 for cold start (electric choke)
Web Advertising - Advertising - Web Advertising - Internet Advertising - Online Advertising test
