Old 02-05-2006, 06:38 PM
Starting problems
help me out guys, sometimes my car wont crank, im getting fuel cuz u can smell it, ive replaced wires and plugs, after i finally get it started its fine until it does it again. . . any ideas?
Old 02-05-2006, 09:03 PM
next time turn the ignition on and off 3 times.. then turn it all the way over... does it start up right away or still take a bit?
is that a mechanical fuel pump or a electrical one?
Old 02-06-2006, 10:06 AM
you said you replaced wires and plugs? Have you actually replaced the starter and starter solenoid? It could be right there.
Either that or your battery has a fried cell in it. Have it checked out at sears, they do it for free.
Old 02-06-2006, 03:49 PM
weve checked the battery and the alternator, replace wires, plugs, control module and its not making the grinding sound of the starter but i replace the distributor cap and rotor today, if it happens again ill check the starter, since i replaced the cap its starting up quicker too (that was one of the problems too)
Old 02-06-2006, 05:31 PM
right but if your solenoid is not engaging the starter gear than it will just make clicking sounds instead of grinding sounds.
Old 02-06-2006, 05:35 PM
check the fuses
Old 02-06-2006, 05:42 PM
Originally Posted by Ta Jay
check the fuses
agreed, in fact thats the first place you should check before doing any other analysis of an electrical system, if a fuse is burnt then you gotta check for shorts in the circuit. Its tough, we will try and help you out.
Old 02-06-2006, 07:28 PM
i jus checked the fuses(IT did it again) and they were fine, i couldnt get to the starter but i heard like a buzzing sound that would cut on and off. . . ive noticed it only does it when ive drove it for a while like coming home from school. . .
Old 02-06-2006, 07:36 PM
Actually you should check the fusible links ( they will be stretchy like a rubber band if one actually goes out). Also it is most likely a ground circuit or solenoid if the starter motor isn't turning slowly all the time. If it is, that is the starter motor creating a ass load of resistance in the circuit. This can also cause the "magic smoke" to be released never to return again.
Old 02-06-2006, 07:43 PM
im jus going to go drop my car off tomorrow at my uncles house tomorrow, its pissin me off, it only does it when im n a hurry. . . u know how that is
Web Advertising - Free Advertising - Free Advertising - Online Advertising - Web Advertising test
