Old 01-01-2006, 12:46 PM
maroontransam maroontransam is offline
Send a message via AIM to maroontransam Send a message via Yahoo to maroontransam
Rear end makeing some noise!!!
rear axle makes noises when i start from a complete stop...wut do u think it could be?
Old 01-01-2006, 03:46 PM
oh boy.
Old 01-01-2006, 05:02 PM
thanks for the help!!! :smt023
Old 01-01-2006, 05:07 PM
Give us more info.. what type of noise... humming, grinding, thumping..??
Old 01-02-2006, 12:27 AM
its kinda of a wining noise that gets louder when i acclerate...the wining noise starts over every gear and gets louder ...
Old 01-02-2006, 03:45 AM
well it it starts low at every gear and then gets progressivly through the gear then its the tranny... if it just gets progressivly louder as you speed up then its the rear...
noise changes by what gear your in - tranny
noise changes by what spped your at - rear end
do you have any modifications done to the suspension at all?
like:
-torque arm
-lowering springs
-dropped LCA brackets
or basically anything that could change the pinion angle at all?
Alright if it is a whining noise during acceleration does it continue if you let off the gas and let the car engine brake? if you have a manual take it up to like 4,000 rpm in say 3rd... let off the gas suddenly and let the engine slow it down. Does it still whine? A whine from the rear axle usually points to the gears as the problem...
lets hear some more info
Old 01-02-2006, 11:32 AM
took it from 4,000 rpm and there was no whining... only thing on suspension that is after market is kyb shocks... the axle and tranny i put on in august...
i have a automatic transmission... and it does keep whining when i let of the gas...
Old 01-02-2006, 11:58 AM
FireBirdGirl02
I had a humming noise coming from the rear end of my car and the guys that work on my car said its the Pinion Barings. Might want to check that out.
Old 01-03-2006, 04:46 AM
way to check it is easy...put your hand on the output/yoke... and see if you can wiggle it side to side...
although is this a whine or a hum?
is this a consistant noise or does it change or anything between gears?
Old 01-12-2006, 04:13 AM
Blue02Formula Blue02Formula is offline
It's probably pinion bearing. Check to see if the pinion nut is loose or fluid leaking around the seal.
Web Advertising - Web Advertising - Online Advertising - Advertising - Internet Advertising test
