Old 06-24-2005, 04:17 AM
chris5388 chris5388 is offline
Send a message via AIM to chris5388
Creeking sound from rear
Hello,
In my 95 Z28 I have this out of control creeking sound coming from the rear end. It happens whenever I drive around or when I make a sharp right turn.The noise sometimes goes away when I lube everything down underneath my car but then it usually comes back within a week or two and gets really loud. I never had this problem until I got in my accident and the rear of my car hopped a curb pretty hard. I had to replace the panhard bar, rotors and the left side axle shaft. If someone could give me some ideas on what my problem could be I would appreaciate it.
Thanks,
Chris
Old 06-24-2005, 04:31 AM
Re: Creeking sound from rear
Originally Posted by chris5388
Hello,
Thanks,
Chris
I think the Vice President has the same thing you are talking about, right TaJay?
Old 06-24-2005, 06:00 PM
Originally Posted by SLP LS1
Hello,
Thanks,
Chris
OK, I just some how deleted everything I wrote so now I am pissed lol. If it is clicking around corners and in reverse it is the posi for sure. It either needs servicing or when it was the additive wasn't put in. If this is not the case it could be hiddin damage like the exhaust rubbing when it gets warm etc...
If you took the car somewhere to have it repaired which I hope you did considering the damage inflicted on the suspension then I would return there and tell them what's up. Otherwise it is hard to tell without hearing it.
Old 08-03-2005, 08:22 AM
CHECK THE REAR SPRINGS. THERE SHOULD BE A RUBBER BOOT ON THE TOP AND BOTTOM. IF IT'S NOT THERE OR IS DAMAGED THEN IT RUBS METAL TO METAL AND CREEKS LIKE A DOOR.
Old 08-03-2005, 05:51 PM
seems 90% of 4th gens have that noise check your suspension that everthing is intact spray some lube on the upper and lower spring perchs and turb up the radio
Old 08-03-2005, 10:42 PM
JoeliusZ28's Avatar
JoeliusZ28 JoeliusZ28 is offline
Location: Macomb MI during the summer, GVSU in the winter
Send a message via AIM to JoeliusZ28
my car squeaks pretty good taking sharp corners too. I know i dont have any issues with the posi though ( :smt077 ) and the fluid is fresh. I always thought maybe it was the brake pads making contact or something because of the pressure on wheel mount.
-Joel
Old 08-04-2005, 05:50 PM
I dont recall ever having that problem with my 3rd gen...
Old 08-04-2005, 05:56 PM
yah, i have the same noise. who knows what it is!! sumtimes i think its the spring not seated correctly, sumtimes i think my rear is about to fall outta the ass. so far so good. when i corner tho it rattles around. it comes and goes. i took the spring isolator out in the rear to get the rear to sit lower, but i cant remember if i had the problem b4 i did that or not.
Old 08-04-2005, 08:10 PM
lube the spring moiunts tigetn everything and dont worry about it
if you jack up by the body and let the axle hang you can put some thick grease on the springs top and bottom it will stop the noisefor a while
Web Advertising - Web Advertising - Internet Advertising - Internet Advertising - Online Advertising test
