Old 07-17-2006, 11:56 AM
2fast97z 2fast97z is offline
Send a message via AIM to 2fast97z
eh lt1 rods cant handle that much as you can see...they definately hold up for a while though but when they break they do this
[/img]
97 Artic White Z28
Built 357 Cu. In. LT1
Old 07-17-2006, 08:40 PM
j0n j0n is offline
Send a message via AIM to j0n
sweet carnage! i stand corrected :smt025
Old 07-18-2006, 06:39 AM
Colossus Colossus is offline
Send a message via AIM to Colossus Send a message via MSN to Colossus Send a message via Yahoo to Colossus
How much power were you making on the ground? See, the pistons are generally okay as long as you have a good A/F ratio. The rods are almost always the weak link in a powerful stock bottom end car. The cranks are good for a lot more than either the pistons or the rods.
How much horsepower can you have and still go to heaven? More importantly, how much torque?
Women are like Voltron, the more you hook up the better it gets.
Old 07-18-2006, 07:51 AM
Originally Posted by Colossus
For the record I'd just like to say that a cast iron block (LT1) is stronger than an aluminum one (LS1). LS1 is a good motor, don't get me wrong, but the LT1 block is stronger. If you want a stronger LS1 style block go with a LQ9 6.0 litre truck block. Its cast iron.
If you opt for the LT1 I reccomend the Corvette engine as it is a four bolt main. If your building the engine get the Camaro/Impala engine and splay it to a four bolt.
If your putting boost to a stock block go with a Procharger kit. With the intercooler option you can push 12 psi to a stock LT1 if I'm not mistaken. Don't do anymore though. With that I would do supporting mods (i.e. headers, intake, etc) but wouldn't go heads and cam. The engine won't like it.
Also a tune can be more conservative and use more fuel and give the engine a longer life. The leaner you go the more power you make but theres a bigger chance you can lean out the engine. Not a huge deal on an naturally aspirated car, hell, not even a problem really. If you lose fuel pressure the engine doesn't care too much. On a boosted vehicle a loss of fuel pressure will immediatly kill the engine, blowing ring lands, melting pistons, and a whole mess of bad things.
The only thing I would worry about on a stock engine would be the rods. If the tune is good your pistons will be fine. The rods on the other hand are the real limiting factor as I understand it. You will break them around 550 hp I do believe.
All good but unless you pick up an LT4, it wasn't a four bolt, even in the Vette (same part numbers even) . Splaying is the way to go. Leaning anything too much is always a prob, it is just exagerated when put on a power adder. It burns valves, pistons, and will pretty much ruin your day. The pistons are hyper-pops, not something I would put in a high power/compression car (which it will be under boost) not to mention the stock crank. None of this stuff is really any good for over 450 crank hp, I wouldn't trust it at 500 unless you never get on it, and then, what's the point other then a piece of paper that says it can?
  #15 (permalink)
Old 07-18-2006, 08:27 AM
LT4s were not 4 bolts?? Are you positive, every spec I've ever read says they were 4 bolt mains
  #16 (permalink)
Old 07-19-2006, 05:46 AM
I'm pretty sure Corvette engine's were all four bolts.
Yes, leaning out is bad in general, but if you lost fuel pressure for a second under boost you can kiss your engine good bye unlike a naturally aspirated one, which it would take prolonged abuse to kill.
I say a stock LT1 can take at least 500 at the crank. I have a friend doing 488 crank hp on a daily driven Formula. The rods go first. Look at the pictures above.
Detonation is what really kills a motor, at least the pistons. I wouldn't take the stockers past 550 crank but its possible to attain that I think.
  #17 (permalink)
Old 07-27-2006, 05:15 AM
no, only the LT4s had 4 bolt mains. I have checked this out several times. The part number for the regular LT1 Vette block was the same as the F-body...
  #18 (permalink)
Old 07-29-2006, 04:20 AM
Then theres a shit load of people with mysterious extra holes and bolts in their Corvettes. :D
Free Advertising - Advertising - Web Advertising - Online Advertising - Online Advertising test
