03-15-2006, 01:30 AM
Late model monte engine swap?
Im considering purchasing an 04 mote carlo ss which is a V6 supercharged. now im curious if anyone has done or knows if a V8 swap is possible. Will it fit? how hard will it be to make it fit? Does anyone know of any V8s that will fit? and finally if not able or if cheaper to just unleash the V6 since its supercharged, would that be better?
Im just looking for any positive feedback anyone can offer it would be greatly appreciated. Even if someone can point me to a site that ight have more info. Im doing some searching on my own. Thank you for your time.
03-15-2006, 01:40 AM
well 1st are you going to make it RWD?
if not the 5.3 that comes in the new GTP(if not GXP i get confused) would fit. If you wanted a different motor than that(which 305hp isnt bad at all) im sure you could find something that could make the bellhousing to fit to the auto trans.
Id probably save the money from switching the v8 in and mod the 3.8 if its S/C. Beef up the trans and do some sweet stuff to it and you probably wont regret it
Edit: by re-reading you probably are not aiming for RWD. But as i said up there^
It would most likely be cheaper to mod the 3.8. Strong motors weak trannys. beef up the trans and mod up the motor and youll have yourself a fun little car.
Chris Sneesby
1988 Mustang LX Notch 5.0: BBK shortys, flowmaster x-pipe/american thunder exhaust, 3.55's
1984 Regal---350SBC, TH350, Edlebrock cam/intake/lifters, Holley 650 carb, 3" side exit exhaust, shift kit, autometer tach, subframe connectors,weight reduction,relocated battery etc etc
03-15-2006, 06:04 AM
Unless you have a LOT of money to burn and a lot of skill, build the 3800.
03-15-2006, 11:24 AM
Yea thats pretty much what ive been getting. I would like to make it RWD but i do not know if ill be able to just yet so i will probably go the along the lines of beeffing up the 3.8 if i get one of those. But i am going to have to look into that 5.3. Thank you for your info
03-15-2006, 01:37 PM
It would be a pain in the ass, you would need a ton of money, not only what would be involved in the driveline but then fitting it.
Oy, i would unleash the 6, much cheaper and you wont kill yourself trying to fab up the 8 cylinder.
03-15-2006, 09:32 PM
{a}
Fix up the 3.8, put a turbo on it to spruce up the s/c, fix up the tranny, a rear end, lil suspension :smt023 = One badass V6
03-15-2006, 11:32 PM
Originally Posted by defln67
{a}
hey dude theyre front drive they have a transaxle but i agree beef up the trans and mod the hell outta that little 3.8 ive heard you can get good power out of em if theyre S/C like your talking about getting.
03-16-2006, 01:45 AM
Yea i know they are front drive and i was only going to buy one of the supercharged one. All this is just consideration so i was just trying to do some research about the swap. I have info about everything else we just have such a diverse group here so i was hoping i could use your guys knowledge. And it was a big help thank you very much.
03-16-2006, 02:55 AM
Just to encourage you, a twin charged (turbo into the s/c) GTP hit the high 9's in the 1/4 last fall. Not bad for a full interior car lol.
03-16-2006, 12:33 PM
definitely the v6 with a turbo! I've wondered if swapping the s/c for an n/a intake and putting a nice size turbo and intercooler would work better since turbos are more efficient than s/c's(not that s/c's are bad, just less efficient)
