  #51 (permalink)
Old 03-21-2006, 12:35 AM
Godhatesimports Godhatesimports is offline
Send a message via AIM to Godhatesimports
750 rwhp is alot of power dude, youll beat those ricers. But your 50x more likely to wrap your car around a tree ;). Anyways, Id go with internal engines mods, forged internals, camshaft,springs,lifters,ported heads (with the entire assembly) after that get a Procharger. Build up your fuel system, build it up very good. Youll also want to build the suspension to handle all that power, and most likely youll need to rebuild your trans to handle all that power. Especially if you launch it hard enough youll snap your 10 bolt. Youll definatly need to get a 12 bolt rear end, some sticky tires, and any an all safety mods if you dont already have them.
  #52 (permalink)
Old 03-21-2006, 07:48 AM
Originally Posted by ta12sec
im gonna go with as the pressurized gas is released it changes from a liquid to a gas cauing a cooling effect . that should be fiarly close i think
we heat the bottle to keep the pressure in the bottle at the proper levels
now mr enginer is that a checmical change or is that a physical change
:smt023
Web Advertising - Online Advertising - Advertising - Internet Advertising - Advertising test
