Old 01-08-2006, 09:22 PM
Chevy_Power_68 Chevy_Power_68 is offline
Send a message via MSN to Chevy_Power_68 Send a message via Yahoo to Chevy_Power_68
305 Heads???
Hi i have a 383 stroker, and is making a good amout of power, but it has 305 heads on it, is this a good thing or not?
I rather push my chevy than drive a ford!!!!
Old 01-08-2006, 10:51 PM
Re: 305 Heads???
That depends on a number of factors..
Have you put the head on a flowbench, or know the Flow #'s?
What are the vavle sizes, compression ratio, HP levels, etc..
Im sure it could be a good thing or a really bad thing, we need more info to even come close to knowing.
Old 01-08-2006, 11:04 PM
89VetteFromHell 89VetteFromHell is offline
Send a message via AIM to 89VetteFromHell
if they flow good, then from what i hear the 305 heads on a 350 block actually give it a better compression ratio
1989 Definitly stock Corvette
Reach me at 586-556-1363 !!!!
Old 01-08-2006, 11:58 PM
it has really good comp. 10.5:1 and it seems to flow better than normal heads.
Old 01-09-2006, 12:26 AM
are these stock or aftermarket 305 heads?
Old 01-11-2006, 11:45 AM
they are stock, i heared that the combusion chamber may be to small. is this true?
Old 01-12-2006, 08:19 AM
small in comparison with heads of a 350 and/or aftermarket heads.
a 383 stroker with an aftermarket head the produces the same CR will have better flow rates.
http://www.mortec.com/castnum.htm
check out that site to see what size combustion chambers you have with the casting number off of your head.
Old 01-29-2006, 08:15 PM
Bandit79 Bandit79 is offline
Send a message via AIM to Bandit79
I put 350 heads on my 403, kicked the compression way up 8.5:1 to about 10-10.5:1, they had some machine work done to them tho.
made the car ALOT faster.
79 Trans Am
6.6L Rocket Block
Old 01-30-2006, 01:42 AM
one of the guys i know put a set of old vette 283 heads on a 383 stroker. i said your nuts!! its C/R is 18:1 it runs through trannies like no other.
Old 01-31-2006, 03:19 PM
83-z 83-z is offline
Send a message via AIM to 83-z
im buildin a 350 roller to drop in and i have a pair of 87 305 heads (new) and im not sure if they will help or hurt it....i have been told good and bad things. so im confussed too! :smt017
Online Advertising - Advertising - Online Advertising - Web Advertising - Advertising test
