what do you want to put this engine in? from an 89 truck it's an EFI block which means it's a 1 piece rear main seal, hydraulic roller block(the trucks are usually hyd flat tappet but the block accepts factory hyd roller equipment which mean you don't have to get a retro-fit cam and lifters for a lot more money) and I believe it has PM(powdered metal) connecting rods, which are good.
The heads, from 87-95 have the center intake manifold bolt holes canted. The TBI(throttle body injection) is pretty poor for performance. Do you want to carb it or what? GM and Edelbrock have carb intakes that you can bolt onto the 87-95 truck heads.
If the block was cracked, the heads probably are or are about to, in which case you'd be better off buying a set of Vortec heads and get an intake for it.
And I wouldn't JB weld the block, 350 blocks are too easy to find and that is not at all a permanent fix.
