Old 07-19-2005, 03:43 AM
68 Coop 68 Coop is offline
Fuel pump???'s
I'm having some problems keeping pressure on the lines from the pump to carb side I think. Should I go with a 5 psi electric fuel pump for a daily driver??? I was told I did not need one awhile back, but this will be the 2nd mech pump in less than 1.5 years. Any comments or suggestions will be greatly appreciated.
William
68 Mustang Coupe
289
C4
3:55's/Trac-Lok
Old 07-19-2005, 03:50 AM
friend of mine is usually runs 7-8 psi on his 347, and i kno it can go higher. what size r you using now?
Old 07-19-2005, 04:08 AM
Sorry, but I'm confused on what you mean exactly???
William
68 Mustang Coupe
289
C4
3:55's/Trac-Lok
Old 07-19-2005, 06:11 PM
Wheres "The Brad" , im sure someone highly qualified in giving you a good answer will see this in a bit and respond.
:smt045
Old 07-19-2005, 10:22 PM
ChevyGSX ChevyGSX is offline
Send a message via AIM to ChevyGSX
i went with a holley electric fuel pump, and ran it at 7 psi. an old school engine like yours needs no more than that. if you had maybe 450 to 500 hp you might need to go more, but i wouldn't. i got about 350 hp, and it is fine.
My mom's chevelle with a stock 283 has the same pump i do, at 6 psi, and it is fine. just make sure you mount it away from your exhaust, (oops, i did that!).
hope this helps.
P.S. this will be fine for a daily driver, my Duece is exaclty that
Old 07-19-2005, 11:30 PM
i belive by size jay mean how much volume x psi + x units per hour
ie: gallons per hour litreers per hour ect
Old 08-10-2005, 01:47 AM
OK, thanks everyone. I have a in-line regulator installed already, set at 5psi. I was told, that is about all an Edel really likes. So, I figured if I get the 5psi pump, I can eliminate the reg at the same time, and go 3/8 line from tank to carb. Just to update the situation, the car starts, runs and holds pressure now. Strange, but it almost acted like it was vapor locked for 2 days straight. I don't know what happened, but it is OK now. :smt025
William
68 Mustang Coupe
289
C4
3:55's/Trac-Lok
Web Advertising - Web Advertising - Advertising - Online Advertising - Internet Advertising test
