Old 08-17-2006, 12:53 AM
78KingCobra 78KingCobra is offline
Send a message via AIM to 78KingCobra
Timing Help
my car needs to be timed. i personally know nothing about timing a car, but i have a friend who knows how to time. what i need to know is:
on a 87-93 5.0 mustang motor, what is the spark order?
where is the timing indicator thing on the flywheel or w/e.
what is the motor supposed to be timed at?
and im pretty sure on motorcycles, you can advance the timing to where you need to run a higher octane gas to prevent detonation, and that increases power, but can you do that on a 5.0? if so, what would the timing be to need to run 93 octane gas?
is there anything else im missing?
1978 mustang II cobra II. see more and read more at www.myspace.com/flatlandbrodie
Old 10-13-2006, 12:57 AM
mustang196718 mustang196718 is offline
Send a message via AIM to mustang196718
the firing order is 1-5-4-2-6-3-7-8. the timing mark is on the harmonic balancer, which is on the front of the engine attached to the crank. it will usually have a line with TDC (top dead center) next to it, then degree increments up to 8* advance or so. as for the rest of it, someone else is going to have to chime in because this is not my area. hope this helps a little.
2003 Cobra--It LOOKS stock...;o>
1967 Mustang--331 cubic inch stroker
1993 LT-1 Trans Am--SOLD
1990 BMW 750iL--The V12 grocery getter
1990 BMW 325i--The inner-city fuel saver
Xecuter 3 Mod Chip - Credit Card - Discount Magazines - Car Finance - Loan test
