Old 03-26-2006, 02:46 AM
BlackHawkA4 BlackHawkA4 is offline
Send a message via AIM to BlackHawkA4 Send a message via Yahoo to BlackHawkA4
T5 In a Vic
I'm still thinking about putting a t-5 in the vic. I could prob get a used one for 500 bux. All the custom fabrication would probably still come out cheaper or the same price as a I wide ratio AOD. I'm only planing to push out 350hp tops so it should hold up. I just miss driving stick soo much.
FoDoMu
Supermotors
Cardomain
Nice Move!
Old 03-26-2006, 09:08 AM
yeah, it shouldnt be too bad to retrofit, youll have to move the crossmember, get a different driveshaft and yokes.
The interesting part will be dealing with the shifter and the linkage.
I dont see it being overly hard. They do it to my third gens all the time. But then again its a little different.
Old 03-26-2006, 12:34 PM
It's been done. I don't remeber the guy saying anythign about a driveshaft. It bolts right on I Think. They don't make other driveshafts for crown vics. He said it was all easy. The only hard part that took some creativity was making the clutch pedal.
FoDoMu
Supermotors
Cardomain
Nice Move!
Old 03-26-2006, 12:53 PM
I reckon your gonn have to lengten your driveshaft though
Old 03-26-2006, 01:53 PM
Actually mine is too long. I need to get a 90+ Drive shaft. It's perfect lenght. Need to drill some holes int he crossmember. Make the hole in the floor. Custom fab the pedal and boom you got it. Need a differnt flywheel too from a stang with the tranny.
FoDoMu
Supermotors
Cardomain
Nice Move!
Old 03-26-2006, 05:45 PM
Godhatesimports Godhatesimports is offline
Send a message via AIM to Godhatesimports
doesnt sound to bad, keep us updated and post pics if possible.
Old 03-26-2006, 06:19 PM
yeah that definitely sounds easy.
Youll have some fun with that clutch pedal assembly, maybe youll be able to use parts from a mustang and simply adjust for travel lengths and position.
Old 03-26-2006, 10:31 PM
I need to weld something on my pedal cluster... add a pedal from a mustang.. cut my brake in half and wallah. The hard part is cutting notches to make everytng clear. That's not even that hard.
I think I may have score an entire 86 Mustang Vert. 350 bux. Says the body is apart. I want it for the motor. I HOPE ITS A 5 SPEED! I'll take it in a heart beat!
FoDoMu
Supermotors
Cardomain
Nice Move!
Old 03-26-2006, 11:30 PM
t5 is longer then an a0d hmmmmmmmmmm
Old 03-26-2006, 11:36 PM
On a Mustang I guess. On the vic it's not. I'm just telling you what's been said by the people who do it.
http://www.grandmarq.net/vb/showthread.php?t=7690
FoDoMu
Supermotors
Cardomain
Nice Move!
Advertising - Online Advertising - Advertising - Advertising - Advertising test
