Go Back   SEMB Muscle Car Club > Tech Section > Ford - Muscle Car Development > Ford Internal Engine
Old 06-23-2006, 03:16 PM
Mr. Land Yacht Mr. Land Yacht is offline
5.0 question...
I plan on puttng a Ford Racing E303 cam(.498"lift, 220 at .050" duration) into my motor...along with converting it to MAF and putting on GT40 heads. :smt023
my question is this:
Can you put on 1.7 Roller Rockers with a E303 cam and not have piston/valve clearance issues?(total lift would equal .528")
MAGNA 302
1988 Mercury Grand Marquis LS
Cardomain page:
http://www.cardomain.com/ride/411357/1
Old 08-27-2006, 02:05 PM
RadioFlyer RadioFlyer is offline
Don't remember the specs, but you can check by using a small amount of clay on the pistos, where the valve cut-outs are, than install the heads (lay the gasket out and bolt them on tight) and with a cheater bar hooked up to the crank pullie bolt, turn the motor at least one complete revolution. Than remove the heads and check the pistons. It may seem to be a PITA, but it's the best way and next to only way to find out for sure.
Hope this helps ya some.
Old 08-30-2006, 11:12 PM
PLasTiK-DmB PLasTiK-DmB is offline
California Representative
Send a message via AIM to PLasTiK-DmB Send a message via Yahoo to PLasTiK-DmB
Exactly what I was gonna say. I'd rotate atleast 3 times...
{'97 Trip Black GT convert}
-Bassani Catback
-K&N CAI
-Accufab 75 mm TB
-Dragon Plenum
Ford Performance Manifold
-Pro 5.0 Shortshifter
Old 08-31-2006, 08:38 PM
MikesMerc MikesMerc is offline
If these are the "regular" cast iron GT40 heads with 64cc chambers, then yes, you can run the E cam and the 1.7 rockers. If you are running the aluminum turbo swirl GT40s, make sure you have the 64cc heads as they also come with the higher compression 58cc chambers (which will require the use of the 1.6 rockers).
2004 Black Mercury Marauder
Trilogy Eaton SC @ 13.5 PSI
80 Shot NOS
Forged Bottom End
60# Injectors & 90mm SCT MAF
Kooks Headers and Full Custom Exhaust
Eaton Posi, 31 Spline Axles, 4.10 Gears
http://www.cardomain.com/ride/638955
Old 09-01-2006, 11:19 AM
It's still a good idea to run them thru witht the clay on the pistons. just to make 110% sure about the clearance. I would never really go by what the spec says (not that I don't believe them). I just prefer to see for myself that there is enough clearance and, either way, you don't have to worry about bending or breaking the valves.
I would also suggest valve girdles. They'll help keep the valve train from flexing and bending your valves.
http://images.google.com/url?q=http:...F31mkIO4XpzOE=
Hopefully that picture worked, otherwise I'll get another one later for you.
WELCOME TO THE UNITED STATES OF AMERICA
Press "1" for English
Press "2" to disconnect until you have learned to speak English
Diamante nel di Massima
Advertising - Web Advertising - Online Advertising - Internet Advertising - Online Advertising test
