Go Back   SEMB Muscle Car Club > Tech Section > Ford - Muscle Car Development > Ford Internal Engine
  #21 (permalink)
Old 06-23-2005, 04:25 PM
Try spraying carb cleaner around the base were the intake meats the heads. If it bogs down its an intake leak.
  #22 (permalink)
Old 06-23-2005, 05:02 PM
QuarterHorse QuarterHorse is offline
Send a message via AIM to QuarterHorse
When using that method it will run smoother, via pluging the leak for that second.
-Ballz Deep Racing-
  #23 (permalink)
Old 06-25-2005, 09:09 AM
ACTUALLY IT WILL BOG BECAUSE IT PULLS THE CLEANER INTO THE CYLINDERS AND DOESN'T IGNITE AS WELL AS FUEL. THATS WHY WHEN SPRAYING TO CLEAN OUT AN INTAKE OR THROTTLE BODY YOU HAVE TO HOLD RPM MUCH HIGHER THAN IDLE SO YOU DON'T STALL THE CAR. NOT THAT I WOULD KNOW BEING A MECHANIC AND ALL.
  #24 (permalink)
  #25 (permalink)
Old 06-25-2005, 07:13 PM
Windsor377 Windsor377 is offline
Hey, haven't forgot ya....down in Florida and wont be back until the 11th...I'll try to send the spread sheets then.
  #26 (permalink)
Old 10-02-2005, 08:52 PM
reckless01 reckless01 is offline
Originally Posted by BigBoyBoelts
Well the mod motors do have the ticking issue with the back of the passanger side heads...but that almost only on the DOHC motors not the SOHC ones
Well theres one other problem that I've been seeing on the 99-04 SOHC Motors that came with the PI plastic intakes....
They start to develop hair line cracks in the right front corner....
Not sure if it's got anything to do with you're problem, just throwing my 2 cents in... just tryin ta help...
"Yes an engine usually has pistons,
unless it's a poorly tuned nitrous engine,
then, Pistons are optional"_
Brian
04 Marauder - Bone Stock
87 Monte SS- 500 rwhp
01 GT Full intake, Catback, Pullies, Chip and Tune. 13.7 @ 102.5
  #27 (permalink)
Old 11-17-2005, 11:49 PM
Clutch's Avatar
Clutch Clutch is offline
:smt017
Well, something like that could be a number of things. best bet have a mechanic (perferably someone you know) give 'er a listen. if ya don't know anyone best bet would be, find a local shop, nothing mainstream, just a family shop. stop in have reg. main. done there. bring some brews down and chat with 'em just before close. you'll make a few friends that have the knowledge to help ya with any problem ya might have.
Also, my first car was a '86 mustang (4-banger, auto), my fourth car was a '89 mustang (4-banger, man), my sixth car was/is (resto-ing) a '66 mustang (200ci I6, C4). I recommend them as long as you have patients and some extra loot for when the norm FORD sh*t goes down.
BTW, my '66 is gettin a custom 351w, EFI'ed, twin turbo'd and spray'd. (in like 50 years or so)
  #28 (permalink)
Old 01-26-2006, 11:00 PM
Casper98gt Casper98gt is offline
Send a message via AIM to Casper98gt
wow, this thread it weird. Jumps around alot.... so given that. Its my turn at it.... 4.6 sohc or dohc have a natural tick to them. But youre saying it just started. 2001 Mustang V8's used coil on plug theory. The coil packs as they are called often ( not sure if i can swear on here or not yet ) crap the bed. This would lead to a mis in a cylinder and make the engine shake like youre describing.
Also someone mentioned the plastic intakes, starting in 1996 and going until mid 2002 there is a recall on these plastic intakes, if you have a crack or have paid to have it replaced they will reimburse you. You will know if there is a crack though. Most of the time its in the middle of the intake just above the alternator.
So yeah..... thats my 2 cents.
SVT tech, Hybrid tech, Toyota tech.
  #29 (permalink)
Old 01-29-2006, 03:34 AM
Originally Posted by WishIHadACamaro
Ok while we are on a learning ride here, i have a question.
Im restoring an 89' camaro.
Throw out some cheap engine combos that i might be able to pull out of a junkyard.
Oh and where can i find a 6spd transmission for super cheap that might bolt up to the above mentioned cheap junkyard combo.
Shooting for approx 350-400hp. Machining the engine or stroking is not out of the question either.
Just saw a t56 with low miliage in Cruise News for $1400...
  #30 (permalink)
Old 01-29-2006, 07:43 AM
thanks!
Online Advertising - Advertising - Web Advertising - Advertising - Free Advertising test
