ford 5.0L 89-93 tuning?(88-93 california)
was wondering where i should set my timing? i normally put 89 in the car no less, 93 is rare though.
If the mods i have on the car would make a diff i ll provide a list, all are just normal old bolt on stuff, all majior engine components are stock.
where should i set my fule PSI, Also any one know a way i can check my fule pressure? i have a adj fule pressure reg but i dont want to just throw it on with out knowing where its set, i ve seen gauges hooked to fule lines but they where on carb'ed cars so i have know idea where i would hook it up on a EFI set up?
and any other tuning advice anyone thinks might help :)
MODs-
190LPH fule pump
73mm mass air
70mm Throttle body
cold air kit (filter in fender)
shortty headders
2.5" H-pipe with 60 series flowmasters and turn downs
stock stuff that might matter-
intake heads and injectors(19lbs/hr)
and i have a auto computer in a 5-speed car
91 mustang GT 5-speed white
