there should be a half inch square hole in it that a breaker bar will fit in. So on the old one, you take the breaker bar and take the tension off the belt to take it off one of the pullies. Then unbolt the tensioner, bolt the new one on, get the belt all properly routedand then put the breaker bar in the new tensioner and get the belt over the last pully. I know you are working on a newer engine in ann old car, the car the engine came out of would have had a sticker illustrating the belt routing on the radiator support. So before you do this, draw a picturewith the approximate position of the pullies and tensioner and how the belt runs around them so you know how to get the belt back on
